Hi everyone,
Since Delta V v14, SIS alarms can be grouped in user-defined Alarm Groups for improved identification. However, the Alarm Group functionality does not exist for Control Modules.
I am currently working on a project where alarms from different transmitters are located within the same Control Module. Consequently, I am experimenting difficulties when configuring displays in Delta V Operator (Configure) and using the "ALARMS" parameter. One example is when creating a rectangle to represent a transmitter whose Edge Color Property is dynamic and its Data Source depends on the priority of the most important alarm. Since "ALARMS" parameter is associated with a module, area or user, I am wondering how to filter "inside" the parameter ALARMS to consider only the alarms that belong to the transmitter. If I use "DVSYS.Control_Module_Name.ALARMS[1].F_PRI" as a Data Source, I would be considering the most important alarm of the entire Control Module.
In another project, this issue only affected to SIS Modules, so I resolved using Alarm Groups. Hence, I would like to know if there is an equivalent functionality to Group Alarms for Control Modules.
Any comments would be greatly appreciated.
