Hi everyone,
Since Delta V v14, SIS alarms can be grouped in user-defined Alarm Groups for improved identification. However, the Alarm Group functionality does not exist for Control Modules.
I am currently working on a project where alarms from different transmitters are located within the same Control Module. Consequently, I am experimenting difficulties when configuring displays in Delta V Operator (Configure) and using the "ALARMS" parameter. One example is when creating a rectangle to represent a transmitter whose Edge Color Property is dynamic and its Data Source depends on the priority of the most important alarm. Since "ALARMS" parameter is associated with a module, area or user, I am wondering how to filter "inside" the parameter ALARMS to consider only the alarms that belong to the transmitter. If I use "DVSYS.Control_Module_Name.ALARMS[1].F_PRI" as a Data Source, I would be considering the most important alarm of the entire Control Module.
In another project, this issue only affected to SIS Modules, so I resolved using Alarm Groups. Hence, I would like to know if there is an equivalent functionality to Group Alarms for Control Modules.
Any comments would be greatly appreciated.
In reply to Andre Dicaire:
I wanted to express my sincere gratitude for the detailed response you provided. Your thorough explanation has been incredibly helpful in clarifying my doubts and providing valuable insights. Thank you for taking the time to provide such a comprehensive response. As a result, my work team is going to perform a further Alarm Assessment to avoid duplicated alarms and facilitate the recommended action to be taken by the operator. As you mentioned, “it is easy to lose sight of the alarm system requirements and how best to achieve its goals when "Alarms" can be created anywhere”.
