I'm working on a recipe in DeltaV Batch. I have 5 components that will be added as a part of this recipe. The limits, however, are not fixed values. The limits for at least 2 of the components would need to be calculated from the values entered for the other 3 components. If the input parameters are deferred up to an operation, is there a way to have the system calculate new limits as the values for that batch are entered? Can the input values and limits be referenced to a control module to do the calculations?
Thanks for the help on this unusual problem.
In reply to Matt Stoner:
In reply to Kent:
