wireless
good day.. about the 1420 gateway. before I can connect it to my pc/laptop i need a cross cable . can i make my gateway 1420 wireless?in what way? thank you very much :)
  • Hi zar,
    Yes, you can make 1420 gateway to be wireless. Just simply connect the Ethernet port from 1420 to a wireless router access point  (Wifi), and you can access the web-based management software or AMS through this wireless access point from your laptop wifi.
    Please don't forget to configure your laptop wireless ip address to be in the same subnet class as your 1420 gateway ip address :)
    I hope that answer your question. Feel free to reply with your comment for any further information required.
  • In reply to Emmy Lim:
    hi ma'am Emmy thank you for your reply.
    Can you give me exact instruction how to configure my laptop and router :)
  • In reply to zar:
    There is a fast "connect" manual supplied with the gateway.
    The IP address is usually attached to the gateway, propably 192.168.1.(100 ?) subnetmask 255.255.255.0
    If it´s for DV configured then maybe 10.4.0.100 subnet 255.254.0.0.
    Open the network card settings in Win.. , advanced settings-> internet protocol version 4, change the alternative connection to the same as the gateway (change the last number to e.g. 1).
    Then you just type in 192.168.1.100 in your browser, enter the password (in the fast manual) and you are connected to the Gateway.
    If you do not have admin rights on your computer you could run into problems with the certificate from the gateway..
    I would reccomend that you first configure the gateway and router/repeater with cable connection, before you try WIFI
    Niklas Flykt
    Klinkmann Oy
    nikfly@gmail.com
  • The information below is not quite correct.
    When the gateway ships from the factory the ports are assigned the following IP addresses.
    Primary Port will be set to: 192.168.1.10
    Secondary Port will be set to:  192.168.2.10
    Subnet mask 255.255.255.0
    If it is a DeltaV gateway then:
    Primary Port will be set to: 10.5.255.254
    Secondary Port will be set to:  10.9.255.254
    Subnet mask 255.254.0.0
    Yes there is a quick installation guide available and the above information is contained in it.
    Here is the link.
    Question regarding Rosemount wireless technology can be directed to the wireless specialist e-mail box copied on this e-mail
    Regards
    Mark Sagstetter
    Supervisor, Technical Specialist Group
    Senior, Wireless/Communications Specialist
    Phone 800 999-9307
    After Hours technical support 612 860-1836
    From: Niklas Flykt [mailto:bounce-nikfly@community.emerson.com]
    Sent: Thursday, April 25, 2013 1:48 AM
    To: Wireless@community.emerson.com
    Subject: RE: [EE365 Wireless Track] wireless
