We've been having an issue with intermittent bad I/O failures for weight scale indicator (profibus) while system is running and material is pumping out of the tank. When the system is idle / the weight reading is constant, the I/O is reading as good. The wires to the indicator have been checked and are fine. Would vibrations cause the connection to fail and result in bad I/O?
