Hi Folks,
When the "Use Scaling" option is selected for a profibus device signal how are the 0% and 100% of scale values calculated.
In this case the setup is for a PCV output signal (16 bit unsigned integer).
0% of scale is set to 80, 100% is set to 150.
Pressure transmitter is ranged -1 to 11 Bar.
Michael
