5482 subscribers
9 Aug 2022 1:07 PM
PHV trend minimizing off screen
1 Aug 2022 5:00 PM
Charms Baseplate Cables- Do I need both?
Rishi Prajapati
29 Jul 2022 6:49 PM
DeltaV Live Faceplate for Smart Switch
arulgeorge
21 Jul 2022 5:11 PM
BAD signal in a LSDO output
Invalid String
20 Jul 2022 9:25 PM
Embedded Trend - Historian Connection
How do I configure a PIN (Pulse Input) function block for shaft RPM.
DI as Pulse Input (PIN) for belt speed
deriving a flow rate from a pulsed input - is the Pulsed input function block the right block for this application?
Timed Pulse Function Block
Turbine Flowmeter Pulse Input to DeltaV
How do I wire pulse device to a Series 2 Multifunction I/O Card installed in backplane as card #5 with an MDPlus controller.
The pulse generator is a CAT magnetic speed pick up generating up to 2500HZ, voltage of 12Vac across its terminals. Do I wire this directly to the multifunction card via an SD32 barrier just like that? I have one speed sensor wired this way to terminals 25/26 of the I/O card but it seems not to record any frequency at the DCS. Please help.
