5482 subscribers
frankfu
17 Aug 2022 2:49 PM
Fuzzy logic control in DeltaV
Steven Cox
15 Aug 2022 1:18 AM
Randy Pratt
12 Aug 2022 12:47 PM
Bruce Rourks
11 Aug 2022 4:55 PM
Faceplate for secondary loop
frankfu
10 Aug 2022 9:11 PM
How do I configure a PIN (Pulse Input) function block for shaft RPM.
DI as Pulse Input (PIN) for belt speed
deriving a flow rate from a pulsed input - is the Pulsed input function block the right block for this application?
Timed Pulse Function Block
Turbine Flowmeter Pulse Input to DeltaV
How do I wire pulse device to a Series 2 Multifunction I/O Card installed in backplane as card #5 with an MDPlus controller.
The pulse generator is a CAT magnetic speed pick up generating up to 2500HZ, voltage of 12Vac across its terminals. Do I wire this directly to the multifunction card via an SD32 barrier just like that? I have one speed sensor wired this way to terminals 25/26 of the I/O card but it seems not to record any frequency at the DCS. Please help.
