How to restore Events
Hello everybody,
I need to restore events to event chronicle. Our System is running with History server 1 and 2 + Backup Server (ArcServ).
I've restored a Backup file with ArcServ, it works so far. The restore file contains one folder per Station (PPlus, Hist1,Hist2....).
In the Hist1 folder  I've found "DVEventJournal", wich contains for example "SVHST1#20130120120008.BAK".
I tried to open this "SVHST1#20130120120008.BAK". with "Restore" in the Event Chronicle Administrator. But nothing hapends.
What should I do to "convert" this ".BAK " to ".mdf".
Thank you for your help.
Have a nice Week end!
Christophe.
  • When you select the Restore Directory in the Restore Event Chronicle Data window does the window populate with your data set details? If so, and you click "Restore" what does it tell you if you click "Details" after it completes?
  • In reply to Steven Estes:
    No the populate window and the "Details" Field stays empty...
    Should I select a specific folder where to put the .BAK files?
    I 've simply copied the files from Bakup server and put them on History server in "Chronicle"
  • In reply to LostEngineer0:
    You can put them in any folder really, so even if you just wanted to make a folder on the desktop and put the .BAK files there it will work. Make sure that you have the specific folder selected down to the lowest level where the .BAK files are located. Try creating a folder on the desktop of Hist1 server that contains only the Hist1 .BAK files and select that folder as the restore directory. You should see the data set list populated with the details (Start time, End Time, etc.) then you can restore those data sets.
    Thanks a lot!
    It works, I've retried step by step and the data are now on the the system.
    I can not see answer to this question , How can I find it
    Gajanan Vispute
