DeltaV Excel Add-in
Hi, has anyone any experience using the DeltaV Excel Add-in to AUTOMATICALLY write values to a module? without having to click the manual update button in the menu bar? if so I would be interested in seeing your vbscript. I've copy and modified the DeltaV Excel Add-in vba code and am having some intermittent issues.
1) A message about having no time interval set, so a default of 0 will be used.
2) A message about having no cells selected that contain DeltaV write functions. I seem to get this if I save my excel spread sheet with a range a cells selected that don't contain the DeltaV write function.
  • In reply to timalg:
    In DV 7.4.1 , App station can not be redundant, so I think you are speaking a second historian server….
    On this second historian server,
    - Check if the Excel version is the right version supported by DV 7.4.1 ( As 7.4.1 is a prehistoric version, I Don't remember which version and OS but only 32bits version of Excel are working for addin
    - start Excel on a new sheet
    - then browse to open c:\deltav\excel\deltav.xla
    - then open the report file
  • In reply to LaurentB:
    we use the version DV7.4.2 .on each historian server there is file deltav.xla on c/deltav/excel folder.and each server creates the same report files .
    the OS of each historian server is windows server 2003 ,
    the report files retrieve data from 4 different field(4 different report files are created,report of field 1,report of field 2,report of field 3,report of field 4)
    each report file can be created automatically and send in an other workstation and send via email,it can also be created manually.
    now the historian server 1 is creating report file automatically of 2 field only and we can not create file reports manually
    in thehe historian server 2 report files can not be created automatically and manually
    we use excel 2003 version.
    in the historain server 1 when i started excel sheet and browsed to open deltav.xla I found the file opened file empty
    in the historian server 2 when i started excel sheet and browsed to open deltav.xla I got the following message error:Microsoft excel A document with the name DeltaV.xla is alraedy open,you cannot open two documents with the same name,even if the documents are in different folders.to open the second document,either close the document thats currently open,or rename one of the documents.
    Is there any solution or do I have to do the restore of the historian server?
  • In reply to Andre Dicaire:
    Please is there any solution or do I have to do the restore of the historian server?
    I don't see how your issue is related to the Historian Server, or how restoring this machine would address an issue in the DeltaV excel addin.
    But v7.4.1 is very far in my past and I simply don't have any resources to go to in order to provide you with any further assistance. This was the first release of the DV CH (Continuous Historian) and replaced OSI PI.
    You've mentioned DVREAD and DVWRITE, which will be OPC DA runtime data, and also DVCHVALUE, which would be a History Server call.
    The only thing I can suggest to you is to start fresh and review the installation requirements for the Excel Addins. Start with a fresh sheet and create some test references using the configuration dialogs and walking through the creation of some runtime reads and history reads.
    This will do two things. a) ground you on the syntax of all these commands and b) if they work in this sheet, will tell you the issue is in how you've copied the file or how the file is configured. Since the Addins were VB based and could be modified, we have no idea if your issues are caused by VB customizations, incomplete fields in the spread sheet or a more foundational issue.
    But if the Historian is collecting data, and you can view trends from it in PHV, and you can read data with OPC Watchit, your issue is not likely related to the DeltaV software, but to something in the spreadsheet. Drastic action to restore the server does not seem warranted.
    Do you have the option DeltaV Real-time Data, v4.1 checked? See below
  • In reply to Lun.Raznik:
    HI Lun,yes this option is chekced
    May I get a copy of the Excel file? [email protected]
    I have just sent it
    Got the files.
    I saw one challenging item for your issue. DeltaV Reporter functionality is used in the worksheet. Unfortunately, if I remember correctly, DeltaV Reporter was released beginning DeltaV v9.3.x.
    Can you use OPC Mirror to get data from v7.4.2 system into the other newer system?
    Or you can use SyTech XL Reporter. But you do have to check it they still support Excel 2003.
    Hi Lun,
    please can you explain;Can you use OPC Mirror to get data from v7.4.2 system into the other newer system?
    so there is not any other solution?
    Hello. I represent SyTech XLReporter. Since XLReporter V12.6 we have been giving users Workbook functionality without requiring Microsoft Excel. This makes the end solution reliable, stable and independant of the Excel version. The write functionality which you need is supported. You can get an evaluation of the product from www.sytech.com and can contact me, [email protected] for any assistance. Thank you. Bill
    Using OPC Mirror is one option to get data from v7.4.2 to your newer system? I am assuming that you have new system as the Excel file that you sent me used DeltaV Reporter.
    If you take the OPC Mirror route, you have to create landing module on the newer system, then historize that value so that you can use the same Excel worksheet for reporting purposes.
    Have you tried engaging with local business partner or impact partner to help with your situation?
  • Good evening Laurent,
    I hope you are doing well,i have a problem in a professional station(pfs),when i tried to log on on Delta v Logon,i could not write the username the option is greyed,then i tried to run workstation configuration i got the following error message:
    NTSetup Error
    NTSetup::setup Common: Eror adding current user to script.
    Can you please help me.
    Best regards
    Khaled Zikara
    Envoyé à partir d’Outlook
    De : khaled zikara <[email protected]>
    Envoyé : dimanche 16 août 2020 12:42
    À : [email protected] <[email protected]>
    Objet : RE: [EE365 DeltaV Forum] RE: DeltaV Excel Add-in
    Hi Laurent,
    Thank you for your help in the excel worksheet there is an function called DvCHvalue, please I would to know how this function grapps the data.is there a way if this function is running well?
    Regards
    Khaled zikara
    De : LaurentB <[email protected]>
    Envoyé : vendredi 14 août 2020 08:02
    Objet : [EE365 DeltaV Forum] RE: DeltaV Excel Add-in
     Update from Emerson Exchange 365
    LaurentB
    In old version version DeltaV Writes function is accessible into VBA project on XLA . Find deltav Writes function ( remove the msg box code lines)
    Create your own macro to run the "modified DeltaV Writes function" , but in your code before running the DeltaV Write , in yuor code you have to select all the cells
    Sheets("Feuil1").Select
    Cells.Select
    frs.deltavwrites
    also how delta v continuous historian send data to the excel file => it 's more accurate to say How Excel can read into DV Continous historian
    Do to this you have to install DeltaV Excel reporter which install also addins into Excel like excel addin. In most recent version of DeltaV , DV Reporter installer is on DVD disk 1
    In older version of DeltaV , DeltaV Continuous Historian was build on PI , so PI datalink was working , but less powerfull to create scheduled task
    View online
    You received this notification because you subscribed to the forum.  To unsubscribe from only this thread, go here.
    Flag this post as spam/abuse.
