Hi I am a student working on a project and would be grateful for any advice . Using an action block and counter I have sampled 10 values for flow rate across the range of a control valve in 10% increments . The values for flow rate and % stem position are written to internal write parameters. I would like to export the data to excel where i could plot a graph of valve stem position vs flow rate. The Excel add on is installed. Thanks
In reply to RobPerry:
You could just add the fields in Excel using the add tool on (10*2 fields). Configure the update cycle to e.g. 10 seconds. Write/read the values to/from some cells and create the chart.
Niklas Flykt
Klinkmann Oy
[email protected]
