Hi I am a student working on a project and would be grateful for any advice . Using an action block and counter I have sampled 10 values for flow rate across the range of a control valve in 10% increments . The values for flow rate and % stem position are written to internal write parameters. I would like to export the data to excel where i could plot a graph of valve stem position vs flow rate. The Excel add on is installed. Thanks
One option is to use OPC running from some VBA code in Excel. You can use this Siemens example as a basis but use OPC Automation 2.0 as the reference and the name of the DeltaV server is "OPC.DeltaV.1". Use the DeltaV tool C:\DeltaV\bin\opcwatchit.exe to check what you can read from OPC.
support.automation.siemens.com/.../llisapi.dll
In reply to RobPerry:
You could just add the fields in Excel using the add tool on (10*2 fields). Configure the update cycle to e.g. 10 seconds. Write/read the values to/from some cells and create the chart.
Niklas Flykt
Klinkmann Oy
[email protected]
