Module will only open 'Read Only'
I have created a new module but no matter what I try it will not let me edit it. It only opens 'Read only'. I have reviewed some older threads on this issue and checked the following:
  • I am a DeltaV administrator so its not a permissions issue
  • The module is checked out to me
  • It is not class based
  • It is not assigned to a controller yet so I am not in online/debug mode
  • The area the module is in, is assigned to the workstation I am using and the remote session I am using
However, I can edit modules in other areas so perhaps there is something going on with the plant area.
Some other things that might be relevant:
  • It is a state based equipment module
  • I am connecting via a remote session
  • We are using a floating license, but the license manager says I have the engineering license.
