Our team is currently facing a challenge with performing logic modifications on an existing SLS 1508 Redundant Module in a live plant environment. We want to ensure minimal disruption while making these changes. I would appreciate your guidance on the following:
When logic modifications are made and downloaded to an SLS 1508 Redundant Module, is the download performed simultaneously on both the primary and secondary modules? Or is the download first applied to the primary module while the secondary module continues to control the inputs and outputs?
During the download process, will the existing I/O configurations on the SLS 1508 Module be disrupted?
Thank you in advance for your insights and recommendations!
In reply to Tadeu Batista:
