deltav sis 1508
hello gay's ,in deltav 1508 sis system , if the sisNet  have tow domain in one system ,how to transport the security parameters between tow domain。what would be the recommended architecture? do i need add any new hardware?
and a nother question,what is the different between domain publish and system publish in the 1508 card property?
thanks for your help!!!!
  • The difference between a Domain Publisher and a System Publisher, is the first can share Secure Parameters outside its node, but it's contained in its Domain, while the later can share its Secure Parameters across multiple nodes and Domains.
    Architecture wise, the SLS Nodes will be integrated via a Redundant Ring using the SISNet Repeater, a single ring can have multiple domains. The other option is having one ring per domain, and have the domains connected via the SISNet Repeater Bridge port, in this case, you'll need to add switches for the bridge connection.
    Rgs,
