If you use the DeltaV Excel add-in or the OPCWatchit utility to do an online change to Alarm Priority, this change is not showing up in the UPLOAD list from the controller.
However, if we go to the same module in the ONLINE mode and change the alarm priority, the upload list flags it as a candidate to update the PRO+ database.
Is there a hotfix to this issue ?
Note: We are using Deltav ver14
In reply to Scott Thompson:
There is a registry option to turn this on (not sure if it is still there but I suspect it is). See the info in this thread.
But just keep in mind it will log all of them and fill the log up quickly depending on what is being done thru OPC.
