Controller Upgrade Utility error (VerifyData Failed)
When trying to update a new MD+ controller from its stock rev to 14.3 getting the following error
The file in question is confirmed to be in the correct folder. Trying to update different MD+ controllers gives the same result.
There are already some MD+ controllers working on this system running their current rev.
Any ideas what would both cause the issue and resolve it?
  • Do you have the latest Workstation Bundle also installed? There have been some changes lately for firmware updates that require both a certain level of workstation hotfix bundle with the updated controller bundle. For example, in the 14.LTS Hotfix KBA, there is this note: "Before performing a MD+ and SD+ controller flash upgrade, make sure
    to install DeltaV_1431_WS_34_CSS or later."
  • Do you have another workstation from which you can run the upgrade utility? If you get the same error message, yet everything else seems to work, it is unlikely to be a random issue. Having the latest Workstation Hotfix is highly recommended, especially given the KBA referenced by
