Yo!
Im sure others have had the same frustration that I have. I am trying to bring Modbus registers in and everything comes in fine except for the floating points. My addressing is correct, I can get the values in modbuspoll on my computer. The floating points are showing up garbled and irratic. I believ it has to do with the '32-bit Floating point, Bi-Endian' structure and the standard driver just wont do it. I believe I need the Mynah Special Modbus firmware to flash the card so I can get the structure options I need with the special data. Guardian Support wasnt any help. If there is an alternate way to bring the registers in by intiger and then combining/ formatting them to be correct, that would work also. Ive attached the Myna manual that explains the driver. Ive also included the manual for the registers Im bringing in (atmos 41 "pages 19-25" )Thanks in advance!
https://metergroup.com/products/atmos-41/atmos-41-support/?_gl=1*8cbg2v*_up*MQ..*_gs*MQ..&gclid=CjwKCAiAgoq7BhBxEiwAVcW0LO--DcAzA2YmLVAWLurKRaObBxGXAcybEsZUK8moON0Vu0FneR0RPRoCE6MQAvD_BwE
0601.Mynah- DeltaV Serial Modbus manual v1.58s.pdf
Dave Harmon
Automation Specialist
In reply to Andre Dicaire:
