How to Enable/Load "DeltaV Reporter" Continuous Historian Excel Add-In via PowerShell Script
I have an Excel (32-bit) .xlsm document that has multiple Continuous Historian function calls using the DeltaV Reporter Excel Add-In. When I open the file directly in Excel, it works fine.
When I use a PowerShell script (.ps1) to open the file with Excel.Application calls, all the function calls give the error response "#NAME?". I've tried a long list of different things to get around this and I'm just running into the same brick wall each time.
If I leave a blank workbook open in Excel in the background, then the PowerShell script works. If Excel is not already running before the script opens the file, then the Excel Add-In doesn't load. (Note that the COM Add-In portion of the DeltaV Reporter does load automatically at startup of Excel, regardless. It's the Excel Add-In, ContinuousHistorianWF that doesn't load). See screenshot below of the two Add-Ins that load when I manually open Excel. The DeltaV Reporter COM Add-In still loads when the PowerShell script runs, but the other one doesn't.
I need this XLSM file to open periodically (I'm using Windows Task Scheduler to call the PowerShell script, but I'm open to other means), so that a computer from another domain can reference the refreshed values in the XLSM file on demand.
Here's the PS1 content:
# start Excel
$xl=New-Object -ComObject "Excel.Application"
$xl.DisplayAlerts = $FALSE
#open file
$filename = "\\APP\DVData\CondLoadoutAccuload.xlsm"
$wb=$xl.Workbooks.Open($filename)
$wb.Save()
$wb.Close()
$xl.Quit()
# now you only need to release two.
while([System.Runtime.Interopservices.Marshal]::ReleaseComObject($wb)){}
while([System.Runtime.Interopservices.Marshal]::ReleaseComObject($xl)){}
  • In my endless internet searches for PowerShell / Excel automation tips, I finally found the key to the issue. By design, Microsoft does not enable the Excel Add-Ins when Excel is run programmatically. If I open Excel directly, myself, the Add-Ins are active, but since it's my PowerShell script opening the Excel application, only the COM Add-Ins are loading automatically. I found the code needed for the DeltaV Continuous Historian Excel Add-In to load...
    After the application has been opened, add these two lines of code:
    $xl.AddIns.Item("DeltaV Continuous Historian Excel Add-In").Installed = $FALSE
    $xl.AddIns.Item("DeltaV Continuous Historian Excel Add-In").Installed = $true
    where xl is the name of the ComObject "Excel.Application"
    I hope this helps someone else, because it was very frustrating for me to find it, as a newbie to PowerShell and .NET coding.
  • In reply to Brent Hamilton:
    I can only access runtime data after adding the exceladdinruntime from the bin folder. Do you know how to enable access to historian? On DV14 we could pull data from specific historical time stamps, but using the same excel file from a DV14 system on DV15 is not working. I also don't see "DeltaV Continous Historian Excel Add-In when I go to excel options.
