5482 subscribers
Dave Grubwieser
17 May 2023 4:54 PM
Elwin Gansekoele
16 May 2023 12:16 PM
Robin
16 May 2023 12:53 AM
10 May 2023 1:36 PM
EvertZwarts
8 May 2023 10:09 PM
In a domain environment: operation failed because the device should not be added to the AMS device manager database" but the same type of device same version Same revision device was commissioned before.
Pinning Multiple Face plates of same type on the same screen
Two System ID in same PLANT LAN and Same proplus name
Different but the Same
Same Batch number
Same error
Any ideas hos to fix this?
Process Automation Manager
FERMIC
17 May 2023 8:54 PM
Were you trying to comment on another post?
Need to post more information on the issue you are having as this appears like a comment that should be under another thread other than "Same error" title. What error? Screen Shots? etc
Jorge L
17 May 2023 9:12 PM
Yes, I was trying to comment on a previous post.
FERMIC
