I'm not sure what happened but I can no longer modify properties within control studio. It won't even let me change the description of a module. Just leaves OK grayed out. I have to go do it from the same properties box from DV Explorer. My session is licensed as ProStation full span.
DV14.3.1, server 2016
Are you trying to modify a class based module?
Are you able to modify in explorer?
At the bottom of the explorer window do you see your user and configure all/download all?
Is your user an admin or do have all the required permissions/groups set?
Tried logging out and back in?
Download ProPlus setup data?
Are you a domain user?
Any changes to the domain?
Does it work on other stations?
Are you doing this locally or via a base station?
Sorry about all the questions but typically these are the ones that cause issues or indicate where a problem may lay.
In reply to ElectroTech:
In reply to TreyB:
In reply to SBPosey:
In reply to Andre Dicaire:
