Is there a way to "Clear Saved Fault Information" Programmatically?
I have several redundant I/O cards that need to be reset due following scheduled maintenance power outages.
I was thinking/hoping that I could make a display for the redundant cards in order to send the "Clear Saved Fault Information" to the I/O card instead of having to use Diagnostics. Only when both of the following conditions exist:1.) PStatus = "Possible Field Problem ....... Need To Clear Errors To Be Able to Switch" 2.) POInteg = "BAD"
Both of these parameters are not available to DV Operate, so I'm sure that I have to create a module to connect these, but I am not sure what the name of the Parameter to set/clear the Fault.
Is there a book that shows ALL connectable/settable parameters?
Any help is much appreciated.
