Changing primary graphic on remote operator station
hi all, does anyone know the format of the vb code i would use if i wanted to change the primary graphic on a different operator station to the one that would be executing the vb code?
  • Why would you like to do that?
  • In reply to Digital Technician:
    we have a video-wall that by design, doesn't have a mouse/keyboard, therefore we would like the operator to be able to change graphic without the need to plug in a keyboard/mouse. There is only a choice of 2 graphics.
  • In reply to Stuart Jolley:
    Sorry I don't know how to remote command other stations via VB scripts. Nevertheless, I would recommend doing a remote access via Windows Remote Desktop, it seems easier to me.
  • Your best bet is probably to have the station that is doing the control write a value to a control module in your system. Then the video wall can monitor that parameter in the control module and update its own screen based on what if finds in the module.
    thanks for the recommendation but we don't support remote login on our deltav systems.
  • In reply to Brian Atkinson:
    interesting solution, which i can see working if i'm unable to find the correct vb script. thanks.
    To expand on what Brian said, I can share what I did in similar situation. I created a string parameter in the toolbar for the "remote" workstation called ps_NewPicture. I animated the value and tied it to a control module parameter, DISPLAY_AGENT/NEWPICNAME.A_CV. I then created an OnChange event for the toolbar parameter. Now, any time the value in the control module changes, the animated value of the toolbar parameter changes and the OnChange event fires the VB code. You can use the frsReplacePictureOnScreen function in your VB code. Your _OnChange event code might look something like:
    Private Sub ps_NewPicture_OnChange()
    Dim NewPicName As String
    NewPicName = frsReadValue("DVSYS.DISPLAY_AGENT/NEWPICNAME.A_CV")
    If Not frsIsPicOpen(NewPicName) Then
    frsReplacePictureOnScreen NewPicName, 1
    End If
    Exit Sub
    ErrorHandler:
    frsHandleError
    End Sub
    I took it one step further for demonstrations. I wanted to open multiple displays on multiple workstations (or Remote Client Sessions), and also open faceplates. I used the same principle, but with Boolean triggers for the OnChange events and a composite for each workstation in a control module. The composite has Boolean triggers and string values for each monitor up to quad screens, for faceplates and displays. Below is my code for the OnChange events for the faceplate trigger and picture trigger.
    Private Sub pb_FPTrigger_OnChange()
    If pb_FPTrigger.CurrentValue = True Then
    If frsIsTerminalServer() Then
    frsLoadFaceplate "DVSYS." + frsReadValue("DVSYS.DISPLAY_AGENT/" + CStr(frsReadValue("DVSYS.THISUSER/TSNAME.A_CV")) + "/FACEPLATE1.A_CV"), 1
    frsWriteValue "0", "DVSYS.DISPLAY_AGENT/" + CStr(frsReadValue("DVSYS.THISUSER/TSNAME.A_CV")) + "/TRIGGER_FP1.F_CV"
    Else
    frsLoadFaceplate "DVSYS." + frsReadValue("DVSYS.DISPLAY_AGENT/" + frsGetComputerName + "/FACEPLATE1.A_CV"), 1
    frsWriteValue "0", "DVSYS.DISPLAY_AGENT/" + frsGetComputerName + "/TRIGGER_FP1.F_CV"
    End If
    End If
    Exit Sub
    ErrorHandler:
    frsHandleError
    End Sub
    Private Sub pb_PicTrigger_OnChange()
    If pb_PicTrigger.CurrentValue = True Then
    NewPicName = frsReadValue("DVSYS.DISPLAY_AGENT/" + CStr(frsReadValue("DVSYS.THISUSER/TSNAME.A_CV")) + "/MONITOR1.A_CV")
    frsWriteValue "0", "DVSYS.DISPLAY_AGENT/" + CStr(frsReadValue("DVSYS.THISUSER/TSNAME.A_CV")) + "/TRIGGER_MON1.F_CV"
    Else
    NewPicName = frsReadValue("DVSYS.DISPLAY_AGENT/" + frsGetComputerName + "/MONITOR1.A_CV")
    frsWriteValue "0", "DVSYS.DISPLAY_AGENT/" + frsGetComputerName + "/TRIGGER_MON1.F_CV"
    End If
    End If
    End If
    Exit Sub
    ErrorHandler:
    frsHandleError
    End Sub
    The animated value is set at runtime so that I didn't have to hard-code the workstation names into the individual toolbars for each workstation/session.  The animations are set in the toolbar's CFixPicture_Initialize script upon loading in Operate Run, see excerpt below:
      '*** Begin DeltaV Display Agent ***
      'Animate the ps_MyPicture variable with the primary monitor parameter for this workstation
      'Each worksation should have a corresponding WORKSTATION_DA composite in the DISPLAY_AGENT module
      Set objTest = frsFindLocObj(Me, "AnimatePicTrigger")
      If Not objTest Is Nothing Then
            objTest.Source = "DVSYS.DISPLAY_AGENT/" + CStr(frsReadValue("DVSYS.THISUSER/TSNAME.A_CV")) + "/TRIGGER_MON1.B_CV[_NOT_CONFIG_OK_]"
        Else
            objTest.Source = "DVSYS.DISPLAY_AGENT/" + frsGetComputerName + "/TRIGGER_MON1.B_CV[_NOT_CONFIG_OK_]"
        End If
      End If
      Set objTest = Nothing
      Set objTest = frsFindLocObj(Me, "AnimateFPTrigger")
            objTest.Source = "DVSYS.DISPLAY_AGENT/" + CStr(frsReadValue("DVSYS.THISUSER/TSNAME.A_CV")) + "/TRIGGER_FP1.B_CV[_NOT_CONFIG_OK_]"
        Else
            objTest.Source = "DVSYS.DISPLAY_AGENT/" + frsGetComputerName + "/TRIGGER_FP1.B_CV[_NOT_CONFIG_OK_]"
        End If
      End If
      '*** End DeltaV Display Agent ***
  • Hi Stuart
    Chris Lloyd here
    How are u?
    Replacepic is the way to go.
    Assign a module with a parameter
    For the display required if there will only
    Be 2 screens then this can be Boolean.
    This module can run on the operator
    Workstation that drives the mimic
    Display.
    Vb script in toolbar or graphic can
    Run Replacepic with the graphic name required.
    Let me know how u get on.
    Thanks
    Chris
    Sent from my iPhone
  • In reply to petroban:
    Petroban, Stuart, The module referenced above can run in a workstation, provided that workstation is either the Professional Plus or an Application station. Typically, a video wall is driven by a workstation other than the Professional Plus, and this cannot be an Application station, so, the statement that you can assign this module to the workstation driving the display is likely not accurate. But it would be appropriate to assign this module to an Application station rather than a physical controller. The module can reside anywhere in the DeltaV system where Module can run.
