Dynamo
I facing issue when select DI dynamo and select the data source path with friendly name and save when start with operation Run ,the dynamo name appear with friendly name two together in same place .see snapshot
  • Check whether the visibility animations are set correctly for both the datalinks (Modulename and Friendlyname). As per standards dynamos, ModuleName should have "frsVariables.ShowTag = 1" and FriendlyName should have "frsVariables.ShowTag = 3". These animations should be the same throughout all dynamos.
  • In reply to Mantri_Bhushan:
    Same issue still appear
