Non-Critical Mismatch Between Main processor Data
I have 2 SLS controllers that have  "Non-Critical Mismatch Between Main Processor Data" errors.
Does this indicate the controllers are bad or do I just need to re-download to them or some other fix?
When downloading to the SLS controller will there be an interruption / change in the controllers outputs?
Thanks
  • Is it a redundant System? If it is, try to switchover the logic Controllers. That will solve this Problem in the most cases. It takes a litte time after the switchover until the warning is eliminated.
  • In reply to handia:
    Ok that worked, but I had to do the switchover twice on each one and that cleared it up. (I also did a download on that module after each switchover since first switchover didn't fix it.)
