I have a control logic which controls the automatic operation of a drier unit that is timed. The logic controls the system effectively but my problem is, whenever there is power failure, the logic starts from the beginning. I use a calc block to constantly move the timer value to a parameter block and restore its value after power is restored, that did not solve the problem.
I need to know if there is a way I can direct the controller to resume execution of the logic at the point before the power failure.
looking forward to your kind suggestions.
Thank you
In reply to JesseMcNeely:
