Hey guys I am new to DeltaV live and am trying to replicate the ToggleDigitalPoint command that was available in iFix.
What I have is
let RemSw = DLSYS.CondReadA(Dsp.Tag+'/REMOTE_CMD.CV',0)if (RemSw = 0) {DLSYS.WriteAsync(Dsp.Tag+'/REMOTE_CMD.CV', 1)}if (RemSw = 1) {DLSYS.WriteAsync(Dsp.Tag+'/REMOTE_CMD.CV', 0)}
Can anybody give me a heads up on how to do this properly.
In reply to Steve Linehan:
Ben Merryman
In DeltaV Live (DeltaV 14.LTS +) you could add some TypeScript code on a Button by selecting "Custom Script" Action under the Basics/Button properties.
(Note: You could also add a script to another object or group by going to the interaction tab and adding the OnClick interaction.)
Here is an example script for a GEM Yes No action pop up that will close out with a No response after 20 seconds.
var response
var strOnOff
var valCV= (await DLSYS.ReadAsync(Gem.Tag+'/YOUR_PARAMETER.CV')).Value // Read in current Value
valCV == 0 ? strOnOff= "Turn On?" : valCV == 1 ? strOnOff= "Turn Off?" : strOnOff="Error in GEM Tag Assignment. Please contact Engineering" // Write message for popup
response = await DL.MessageBoxAsync(strOnOff, "Warning!", Constants.MessageBoxButtonType.MB_YESNO,20) // Popup called
if(response==Constants.MessageBoxReturn.IDYES) // Yes Selected
WriteAsync(Gem.Tag+'/SP_PARAMETER.CV', valCV== 0 ? 1 : valCV== 1 ? 0 : valCV) // Action dependent on current state
Note 1: Add a DLSYS. in front of the WriteAsync() function. The EE365 Forums wouldn't let the post go up with that function written out.
Note 2: For a context display replace Gem.Tag w/ Dsp.Tag. For a one off button replace Gem.Tag+' with tag path info. The "Tag" GEM parameter will need to be added and configured on the GEM for this script to work.
