EE - Forum Styles
fo
RedLion HMI integration into DeltaV using Profibus
Does anyone have any experience in connection a RedLion HMI to a DeltaV system via Profibus?
  • The device should be a slave and you need to load its GSD file. In Explorer you right click on profibus devicnet container and add device.
    This should create a folder and create a device template that you will use to define a device on a card segment.
    Since this is a slave device DeltaV will write values to its registers for display.
    I have not worked with this device but not sure what your challenge is. If you've done the above please give some additional details.
