Server application trend restart command
Hello, I’m working on DeltaV system Sw ver. 10.3.1 with controllers, work stations and  servers in windows domain.  I’d like to know if is there a command to restart the data collection stopped in a server used like application for trend  without reset the server (the collection was stopped due to not enough free space for normal operation) ?
I solve the problem deleting some old file not yet necessary and reset the server.
Thanks
Emanuele Fallacara
  • I believe you should try 1. Download setup data, 2. If that fails, i believe there is a deltav continuous historian services you can reset (three processes, dvhistorianserver dvhistorianserver_2, dvchscan, run as deltavadmin), 3. If that fails, disable historian, download set up data, re-enable historian, download again. 4. If that fails you may need to read the app/sys logs for clues.
    Thank you guy for your time; first action was to download Setup data but nothing was changed
