We have several drives on site which report back an AVAILABLE status as well as Running Status.
Currently if a Drive trips the DC block will report TRIPPED, however the operators can clear this status even if the drive is unavailable.
Is there a method to maintain the TRIPPED state using an external AVAILABLE signal?
I am aware I could use the AVAILABLE input as an Interlock, but the request is to Maintain the TRIPPED status and indication until the Drive has been reset and is AVAILABLE.
At present the drive feed back is tied to Input 1 and the Available is tied to input 2. In the state mask input 2 is required in both Passive and Active states. (?)
The SP is reset on a TRIP
Device Options (All On except Passive when confirmed)
Any thoughts would be appreciated.
Roddy
