Changing the screen with two monitors
(Google translate)
There is a problem with the circuit display on two monitors.
When you edit a schema it is displayed correctly on the first screen and the second unchanged (the old image).
The two station system: engineering (1 monitor) and the operator (2 monitors).
I tried to change the scheme on both stations - the same result.
What is the problem ?
  • Hello, . I am going to move this to the DeltaV group in the hopes you'll get a quicker response. You can also edit the post by choosing MORE among the options at the bottom of the post and using the tool bar, the icon that says "add an image", add a screenshot or photo- this might also help further your cause.
    Best Regards,
