Dears,
I have some parameters, which are always want to keep like false(0 Value) Value in download time and default time, but when I'm trying to upload/download modules, I'm getting this parameters also in upload side. Is it possible to create Non up-loadable parameters in DeltaV ? if yes then how ?. Thanks in advance.
Regards
If you use a class based module you can prohibit instance from being modified or exposed for modification. That would prevent the parameter from being uploaded.
In reply to AdrianOffield:
