I am trying to create a module for my CIOC power supply voltage, but that parameter does not exist in DVE but it shows to have a path in Diagnostics. I can create a datalink on the graphics but am unable to build a module using that parameter.
You should be able to do this: www3.emersonprocess.com/.../c_charm_dst_browsing.html
You need to get to it using an external reference type parameter, filter on diagnostic parameters. Here is the info
...Diagnostic parameters: References are made to parameters structured around the physical hardware that reflect the integrity of the system.
Note
To ensure that CIOCs provide the highest possible I/O performance, external and dynamic references to diagnostic parameters of CIOCs are not reported in modules downloaded to controllers and do not resolve at run time. If you need to use these types of parameter references in your control strategy download the modules to a workstation's virtual controller...
