Path/File Access Error
I get a "Path/File Access Error" message when switching from DeltaV Operate Configure to Run and vice versa
  • any one can help on this regard..i have tried replace back up folders..but its not working...and faceplate i m opening is opening but of not the same tag but some other ....i am not able to edit the hmi while saving the ediited hmi it gives an error regarding drive security...
  • In reply to Sami Uddin :
    Re-run workstation configuration. It is the most straightforward way to re-initialize these types of problems. Make sure you know the DeltaVAdmin password before you run it, however.
  • Dear Youssef.El-Bahtimy
    Thank you for your reply,  I just reinstall everything with last backup importing in all works Fi9 now :)
    I'm sorry you had to re-install everything, usually workstation configuration by itself can correct these types of setup problems, but I'm glad you got everything running.
