SIS Problem
Hi all,
Looking for some advice on a annunciatior problem.
Basically I have one common window on a annunciatior panel which should trigger on any 1 of 25 inputs.
If a alarm is already standing (annunciator already activated) and another input were to trip it would need to re-trigger  the annunciator and same for 3rd, 4th, 5th etc....
The problem I am having is a cause and effect matrix only allows 16 input, I have attempted the possibility of using two but writing to one parameter or DO from two effects is not possible.
Can anyone suggest ways around this or maybe another function block I could use.
Thanks
