IIoT & Digital Transformation Forum
Secure TCP on WirelessHart network
Recent IIoT & Digital Transformation Discussions
Dan Carlson
1 Jun 2020 7:47 PM
Automate Manual Inspection Rounds
marcio donnangelo
28 May 2020 7:38 AM
Monitoring Pressure Relief Valves as Part of a Digital Ecosystem Reduces Cost and Improves Performance
Brian Joe
16 Apr 2020 2:46 AM
How IIoT Data Can Improve Heat Exchanger Performance
Jake Davies
1 Apr 2020 3:38 PM
Insidious Corrosion of Fixed Equipment Detected Via Predictive Maintenance
Rich Carpenter
25 Mar 2020 8:31 PM
VIDEO: A Cost-Saving Approach to Gaining Asset Visibility with IIoT
IIoT wireless cybersecurity must be addressed up front, starting with selection of a network with the required security features. The article discusses the cybersecurity safeguards built into WirelessHART.
WirelessHART Security Update
WirelessHART Not Affected By WPA2 Security Vulnerability
Should 5G Be Your Protocol to Handle Backhaul for WirelessHART Networks?
2011 Emerson Exchange – Wireless Field Networks are Secure
I need some help with this issue.
Who can help here?
Adi
Security Setup
HartTalk
WirelessHART
Secure Tcp
gateway
Jonas Berge
1 Dec 2014 2:01 PM
WirelessHART does not use TCP. That is, there is no TCP between the WirelessHART devices and the WirelessHART gateway. WirelessHART has a number of security measures such as encryption, authentication, sequence number, and key rotation etc. which are always on - i.e. you do not need to do anything special to turn it on.
TCP is used between the WirelessHART gateway and the host (system). It can be secured using SSL per protocol e.g. HTTPS, Modbus/TCP secure, HART-IP secure etc.
AdiTzoref
1 Dec 2014 2:10 PM
Yes, this is what I ment.
I have some questions:
1) How can I make a regular TCP connection between the WirelessHART gateway and the host (system)? (Instead of Secure Tcp)
2) How can I send an authentication details externally and not through the HartTalk program? Because I want to make a connection without the HartTalk.
Adi
Jonas Berge
1 Dec 2014 2:17 PM
AdiTzoref
What is HartTalk? I am not familiar with this program. Please provide link to website
For Emerson gateways use a web browser and go to Setup\Security\Protocols - there you can enable the application protocols you need
Note that it takes more than TCP/IP to communicate. You need to use an applicaiton protocol like Modbus/TCP, HART-IP, EtherNet/IP, or OPC
HART-IP is explained in these articles:
Hart-IP: Large Scale System Integration
http://www.ceasiamag.com/article/hart-ip-large-scale-system-integration/9526
Smart Sensing: Situational Awareness
http://www.iaasiaonline.com/more.php?id=2222&cat=im
Power of Two - New Wireless Solutions for Plant Operations
http://www.ceasiamag.com/article/the-power-of-two/9121
