Dear sir
can you please clarifiy me what are the advantages in daniel dual chamber orifice meter for custody transfer - crude oil
whether dual chamber orifice meter and daniel senior orifice meter are same
with thanks
prabhu
Daniel Senior Orifice Fitting, which is a dual-chamber orifice meter can be used for crude oil custody transfer depending on specific flow conditions.
Before making a decision about using Daniel Senior Orifice Fitting for crude oil custody transfer, great consideration must given to cleanliness of crude, temperature, pressure, viscosity and other flow conditions.
Today, flow in most crude applications is measured using turbine meters, PD meters and in some instances venturis.
Khadra Helminski
