5478 subscribers
nalteir
4 Jan 2021 8:44 PM
Close faceplate when changing operator window
2 Jan 2021 8:08 AM
DeltaV operate(Run) redundancy
Stuart Jolley
12 Dec 2020 8:52 PM
scientific notation to standard form
Mark Bendele
9 Dec 2020 9:20 PM
PIDPlus appears to turn off after GAIN or RATE changed
Ygaikwad1978
9 Dec 2020 12:15 AM
If we have to create HI/LO and HI HI/LOLO alarm on SX controller diagnostic parameters.
DELTAV RESOLUTION COMPLAINT
DeltaV 13 or 12 bits resolution
DeltaV Batch Reported Parameter Name Set Resolution Issue.
v13 monitor resolution
RDP with 1920x1200 Resolution
RE: DELTAV RESOLUTION COMPLAINT
Greetings sir,
DeltaV Version: 7.3
I currently have issue with delta opening in complete resolution in
1366*768
But it Opens fine in
1024*768
, please how can I go about this.
Thanks
Kind Regards,
Agbita O. Wisdom
PCS Tech.
Mobil Producing Nigeria Unltd.
Qua Iboe Terminal
Mobile: 07031526341
OUR VISION:
To Make A Difference To Customers In A Timely, Innovative And Creative Manner Everyday Using All Available Resources At Our Disposal.
“Every company leverage the strength of its professionals. If a company is great the professionals made it so” ----by Gabriel Fagade.
Agbita, Wisdom O /C
Sent:
Wednesday, October 23, 2019 10:34 AM
To:
[email protected]
Subject:
Greetings sir,
1366*768
1024*768
Thanks
Kind Regards,
Agbita O. Wisdom
PCS Tech.
Qua Iboe Terminal
Mobile: 07031526341
OUR VISION:
Scott Thompson
23 Oct 2019 5:34 PM
DeltaV v7.3 only supports two display resolutions: 1024x768 and 1280x1024.
1366x768 is a widescreen resolution and while still not supported could probably be made to work if you were at DeltaV v8.4.1 or higher.
