I have a command driven SFC that has five different commands that run different valve position sequences, is it possible to write a 6th one that when activated will stop the others from running and then execute the sequence in this command, ie if I have executed any of the sequence 1-5 and this is running through to position certain valves I would like to press a button and this sequence stop and active a close all valves sequence (Sequence 6)?
If not am I best moving all the code to a PLM with command driven run logic?
In reply to Matt Stoner:
In reply to GaryL:
