I want to detect, from within a control module, whether DeltaV Operate is running on a workstation.
I set up a simple watchdog system where a VBA procedure writes to the control module every 5s. This works fine except that the online change file for this module is growing rapidly as each write is recorded.
I wondered if there was a parameter that could be read from the module which would indicate when Operate was not running, even if this was just by its CST going bad. OPCWatchit shows some apparently useful parameters in the WS/Operator group such as EXIST but when selected in OPCWatchit they all report Bad, Comm Failure. In any case these parameters don't appear in the list of diagnostics available from the Expression Editor dialogue in Control Studio. Does anyone know of a suitable parameter, accessible from a control module?
The alternative might be to live with a big online change file. Does the system limit the size at some point?
In reply to Matt Forbis:
In reply to Cedric Dawnhawk:
Leo
In reply to Leo Paradis:
In reply to Andre Dicaire:
