DeltaV AI block scaling
I am not exactly figure out scaling in AI block for conventional transmitter.
I want to know how Field_Val (unit %) is calculated for different L_Type.
My understanding -
1. xD_SCALE low scale value = value for 4mA current and  high scale value = value for 20mA filed current.
2. In Direct scaling,OUT = FIELD_VAL% of OUT_SCALE where OUT_SCALE is copied in xD_SCALE means  (What will be value in FIELD_VAL parameter and how it will be calculated).
3. In indirect scaling, OUT = FIELD_VAL% of OUT_SCALE where FILED_VAL = how much % of filed current is w.r.t. xD_SCALE.
4.In square root scaling and In direct independent scaling ...........................????
Thankyou
  • Have you looked in DeltaV Books Online?
    • It isn't just as simple as the L_TYPE, OUT_SCALE, XD_SCALE as it also depends on how the input is being read from the DST (FIELD_VAL_PCT, FIELD_VAL, HART_FIELD_VAL, etc) to know "how" to set these parameters.
    • In BOL, go to Configuration -> Function Blocks -> I/O Blocks -> Analog Input (AI) function block -> Analog Input function block execution
    Your items listed in 4 are typically used when an orifice is being used for Flow (and a transmitter doesn't already account for this) for Ind Sqr Root and when RTD/Thermocouple inputs are used for Direct Indep (Not Indirect independent).
  • In reply to Matt Stoner:
    Thanks Matt for your valuable response,I am referring to Book online and block configured for our plant operation,Today i was again trying to understand it and concluded following :-
    (Following are for conventional NON-HART 4-20ma transmitter).
    (OSH = OUT_SCALE_HIGH and OSL = OUT_SCALE_LOW)
    (FILED_VAL_PCT = M% in every case)
    1. Block execution flow is
    Finding FILED_VAL_PCT (Unit=%) = the % of channel loop current w.r.t 4-20mA current range -------> Calculating FIELD_VAL (Unit = %) ------------> Calculating PV (unit = unit of OUT_SCALE) ---------> Calculating OUT
    2. For L_TYPE = Direct scaling
    FILED_VAL_PCT (Unit=%) ------------> FIELD_VAL = M% of XD_SCALE (Where XD_SCALE will always be same as OUT_SCALE) --------> PV = FIELD_VAL% of OUT_SCALE --------------> OUT = PV (Considering mode is Auto)
    3.For L_TYPE = Indirect scaling
    FILED_VAL_PCT (Unit=%) ------------> FIELD_VAL = M% of XD_SCALE --------> PV = FIELD_VAL% of OUT_SCALE --------------> OUT = PV (Considering mode is Auto)
    4. For L_Type = Indirect sq.root
    PV = Sqrt( FIELD_VAL% divided by 100) * (OSH-OSL) + OSL --------------> OUT = PV (Considering mode is Auto)
    5. For L_TYPE = Direct independent
    Still struggling to understand.
    My Point is
    Is my conclusion in point 1 is right ???????
    IS other point 2,3,4 concluded are correct??
    Matt i am truly thankful to you for sparing out your precious time.
  • In reply to Devpriy sahu:
    Direct L_TYPE means XD_SCALE is not used (OUT_SCALE will be copied to XD_SCALE) and FIELD_VAL would be typically used for when getting a decimal Hart value.
    Indirect L_TYPE is scaled in linear fashion, this is typically the 4-20mA use case with DST using FIELD_VAL_PCT, XD_SCALE is 0-100% and OUT_SCALE is the range of the instrument.
    Direct Indep L_TYPE means the value isn't scaled at all and XD_SCALE is still used with value plugged into OUT_SCALE. With RTD of range -200 to 1000 °C the XD_SCALE would be set to this range but you probably don't want to display this entire range to operations so the OUT_SCALE is set to the range you wish to see, 0-150 °C for example.
    Indirect Sqr Root L_TYPE would have XD_SCALE as the full scale differential pressure of a flow orifice and the OUT_SCALE would be the associated flow rate for that scale. There is a call on here as an example found here: emersonexchange365.com/.../3584
