Hello, I just moved a PIC folder from one machine to another, both version 13.3.1, and whenever I try to open a graphic, the Error: "Error Number: -2(FFFFFFFE) Method 'WindowName' of object 'IFixDocFrame' failed" after clicking ok on that warning the message
"Reset Operator Interface
The picture just loaded into the Main window is not a main window picture. Functions that would normally replace the picture in the Main window will no longer work. Would you like to open the default layout now to reset the Operator Interface environment?
The inital "DeltaV.grf" file will open, but when I created a copy of it and tried to open that one it would not work. I checked the VariableGroup as suggested in other questions but all the files had that group. In addition, I have the correct settings file but the directory does not open.
Thanks for the help, please let me know anything I should try to do to fix this.
OMB
In reply to bhushan619:
