User Manager & DeltaV Operate Configure
Hi friends,
i have a serious problem. is it possible to allocate an special picture (on DeltaV operate configure) for an special user (as operator or other)? for example, it means that operator could not see some pages on DeltaV Operate (Run).
  • In reply to ThomasZiel:
    Hi Thomas, what you are describing (or pursuing) would be considered a security violation. User Manager is accessible to administrators only, and changes to assigned DeltaV keys can be done by administrators only, by using the correct tools within the DeltaV system, and by following the existing mechanisms to properly set the environment for supported use cases. VB Scripts are not expected to be used to set user privileges, and even if it was possible, it would be an insecure way of doing this.
