Win 7 Pro SP1 (Virtualized inside Oracle VirtualBox)
Hardlock key is passed into the virtual machine and recognized by both Win7 Pro and DeltaV software.
Licensing Properties
It appears as if I have to assign/configure the license for DV Sim but when I rightclick on the workstation and select Assign License, the window that opens has nothing to choose. Same when I select Unassign a License. When I selected CHECK it says all is good. Downloading the workstation is successful.
Now..
when I select Ctlr1 and check license I get this error.. ERROR: This node cannot be downloaded as the ProfessionalPlus Station has a DeltaV Simulate license. Assign/Unassign license are empty as they were with the workstation.
Is my licensing configured right at this point or have I missed something? Do I need to create a different controller type for simulate? And I also cannot commission CTLR1(it does not show under Decommissioned Nodes), but I suspect that is currently due to the license fault, is this thought correct?
In reply to Maarten van der Waal:
In reply to Nova5:
Best Regards,
In reply to Rachelle McWright:
Right, in DeltaV Explorer you see at least 2 main categories: Library and System Configuration. When you expand System Configuration, you see at least Setup, Control Strategies and Physical Network. When you expand Setup, you see at least Alarm Preferences, Security, Named Sets and Licenses. When you click on Licenses, at the right hand pane you should see the License Bundle DeltaV Simulate Standalone with Basic SIS Simulation. This is the license you imported. Now when you expand the Physical Network, you see at least Control Network. When you expand Control Network, you see at least you ProPlus station, which I guess you called VIRTUALDV (I use to call it PROPLUS, but it does not matter here). So when you drag and drop your license to the ProPlus station in DeltaV Explorer, you have your license up-and-running after a download of this ProPlus.
