Changes to Detail Faceplate
Hello,
I need to update the Detail Faceplate on DeltaV Operate. Once I make the change, is there any procedure to update on the DeltaV Operate.
Thanks
  • Hello Darrell,
    Assuming you are modifying the detail faceplate from the ProfessionalPlus, all you need to do is run the “Update popup pictures” utility in DeltaV Operate (while in Configure mode).  This should update all copies of the detail faceplate with the changes you’ve made.  “Update popup pictures” is available through the DeltaV Utilities toolbar group.  You can then download the workstation node where you want to use the modified detail faceplate (this depends on whether the Auto-Update service for that workstation is configured to receive updated displays and charts; set to ENABLED by default, from what I recall).  The procedure is the same when you want to update faceplates.
    Hope this helps.
    Fernan
    Sent: Tuesday, 5 August 2014 9:18 a.m.
    To: [email protected]
    Subject: [EE365 DeltaV Track] Changes to Detail Faceplate
    Hello,
    Thanks
  • In reply to fabuid:
    Thank you so much Fernan, I will try this when I am ready for the change. Thank you
  • Very important poit mentioned by fernan..!!
    I wonder what does the check mark for "Include POC faceplate" does.
    I clicked it while updating the Popup pictures. don't know, what changes it
    made, and how to revert it back.
    please help.
    reg
    Ankita
  • In reply to Ankita Khare:
    By unchecking option Utility skips creating multiple copies of faceplates under path ..../PIC/POC, so it saves time if that faceplates are not used. You can manually delete multiple copied if not required at path PIC/POC/Temp/Faceplate and Backup folder.
