Verified Answer
5481 subscribers
Dave Grubwieser
10 Feb 2025 11:12 PM
Manuel Behrens
31 Jan 2025 7:54 PM
Show Disabled Transition
17 Jan 2025 10:43 PM
saneej
17 Jan 2025 4:17 PM
Mohamed Gamal
15 Jan 2025 7:56 PM
Two System ID in same PLANT LAN and Same proplus name
Delta V Operate support multiple instances of the same faceplate
Connecting two 1420 WirelessHART Gateways on the same fiber backhaul to the DeltaV Primary / Secondary network
Can Delta V Operate support multiple instances of the same faceplate?
Show and write the same parameter for diferent products in display
Answered
Two faceplate is displayed in the same time
Hello,everyone!
I met a problem. I want to display two same faceplate at the same time.for example.dispaly the two Valve's faceplate or two Pump'sfaceplate,But I don't know how to finish it.
AdrianOffield
1 Jul 2014 7:11 AM
Inside the usersettings graphics, inside the script (right mouse button on graphic page and -> Edit Script), you will find reference to multiple faceplates (look for a line “frsVariables.GN_IA_LOCKENABLED.CurrentValue = 1” and uncomment it).
That should give you what you want.
Shuyang Liu [mailto:
[email protected]
Sent:
Tuesday, July 01, 2014 7:00 AM
To:
[email protected]
Subject:
[EE365 DeltaV Track] Two faceplate is displayed in the same time
Hello,everyone!
