View comments for DeltaV VCAT
Here's one that should be easy, but I can't find any documentation on this:
DeltaV Version Control and Audit Trail (VCAT) allows a user to add a comment upon checking in a module (see screenshot below).  If I'd like to view these comments, where would I look?
James Suisse
  • If you select the module you are looking to get the comments for and right click and select VERSION CONTROL -> Then Show History.
    If you select the version with the Action of "Check In", the Details button to the right becomes visible and when clicked, this will then display the comments entered.
  • In reply to superstec:
    superstec,
    That was exactly it.  I've been rummaging around in the "Version Control>Show History" menu for years and never used the "Details" button in conjunction with a "Checked In" entry.
    It's so simple...
    James Suisse
  • In reply to James Suisse:
    The other item you might be use would be to just print the history to PDF. This will also have all the comments associated with each version Check In.
