Change of PID Control Action in Runtime
Is there a way of changing a "Reverse Acting" PID loop to "Direct Acting" in runtime?
I tried to write the values for above "16768" and "17792" using calc block but PID block was not happy and did not change the action
Shoaib
  • You have to put the target mode of PID block to Out of Service, then write your value, and then return the PID block to the mode required.
    Matt
  • You first need to take the block Out of Service, switch the action, then return it to the desired mode.
    Jeff Swennumson
    PCE Pacific, Inc.
  • Nop, but think about it.
    Process should be one direction for a PID taking control.
    If you need something more complex then you have to implament a more complex control strategyt (maybe two PID and a selection logic)
    De: snizami [mailto:[email protected]]
    Enviado: Thursday, December 19, 2013 02:27 PM
    Para: [email protected] <[email protected]>
    Asunto: [EE365 DeltaV Track] Change of PID Control Action in Runtime
  • In reply to gamella:
    See this previous post about Reverse/Direct changing and the way to do this.
    community.emerson.com/.../5250.aspx
