Guys,
I would like to create a visibility condition for an object in iFix, similar to the one which is looking for the user key "CAN CONFIGURE".
DeltaV Explorer is animated in function of this
DVSYS.THISUSER\CAN_CONFIGURE.F_CV
(Somebody who has no config user locks, won't be able to open DV Explorer).
What I would like is to set a similar condition with the Can Calibrate user lock.
DeltaV iFix help states that there is an expression:
DVSYS.THISUSER\USER_CAN[AREA_NAME][LOCK_NAME].F_CV
I've tried to use
DVSYS.THISUSER\USER_CAN[REPLACE_DEVICE].F_CV
and
DVSYS.THISUSER\USER_CAN[CHANGE_DEVICE_DB].F_CV
which are Can Calibrate locks, but it didn't work.
Did somebody use this before?
Many thanks!
Barka -
I've used this before for toolbar button visibility with the following syntax:
DVSYS.THISUSER/USER_CAN.B_CV[AREA_NAME][LOCK_NAME]
The Lock Name should be one of the locks listed in User Manager, so the lock name you would use is [CAN CALIBRATE], unless you have specific locks named "Replace_Device" or "Change_Device_DB" which I do not have.
There is a KBA out there regarding the specific syntax. Hope this is helpful.
Kathy
Kathy Pate
Toray Carbon Fibers America
Decatur, AL 35601
[email protected]
