Kathy Pate
Toray Carbon Fibers America
Decatur, AL 35601
[email protected]
Hi Kathryn,
Search for a file called Resourcefile.txt or something similar to that in the local folder of ifix/graphics. This a simple text file containing the # to string lookup. The original purpose of this was to allow language specific localisation. So you could easily use the same faceplates and detail displays for different language operators without the need to alter the display, just change the text in the resource text file.
Hope this helps
In reply to IntuitiveNeil:
The file Neil is referring to is located in the Graphics-iFix/Pic/Standard folder.
You will probably see more than one file:
ResourceFile.txt - English
ResourceFileES.txt - Spanish
ResourceFileFR.txt - French
ResourceFileGE.txt - German
Matt
In reply to Matt Stoner:
Cheers Matt,
Spot on.
My memory faded on the exact location.
Thank you, I found the file:) I will probably have more questions about this after I've had a chance to play with it.
